Re: Electroless nickel and metal epoxy?
JB Weld is actually an epoxy with some metal in it (probably similar to devcon if you've seen that).
I'll probably redo the epoxy parts with soldering.
As a seperate question, how do I mask off a section that I don't want to be plated? Is lacquer going to work?
Steve
