i dont follow your logic.
at 13.8 volts with .89 amps would indicate a resistance of 15.5 ohms 3 minutes into the process. considering that par for that amount of sq. footage would be 12.63, i dont see how this shows a correct anodizing curve.
there's also the fact that he reached 15.9 volts after 30 minutes, which indicates 17.87 ohms. this is about 5 ohms too high above par, not to mention an hour early.
if this is a good example of how LCD is supposed to work, then i was way off the entire time.
