i don't think vinyl will work that good .. i use it to letter cars and even the heavy duty vinyl is thin.... plus it cost alot .. i think electrical tape is thick and i noticed that it has a high cut rate... and you use a plotter to cut it the dot matrix will not cut it... and the ink smears so you will not get a good line ... i tryed it when i started ... working with vinyl ...
