Old 01-15-2004, 07:54 PM
Sid03 Sid03 is offline
Sid03
When I said there were no bubles forming on it, I meant that no bubbles were staying on the part.......they rise off the part. I was thinking that they would only have a negative effect if they stayed on the part.
So, do my other dye Ph values seem ok?The two that contained the red dyes(red and orange) have higher values then the other dyes, and they all have higher values then what caswell said teh red should be. Can anybody else measure their dye Ph, and maybe some distilled water also to compare?
As for connection, on this part I drilled a hole smaller then the aluminum wire I use to connect, and twist and push the solid 12 gauge wire into the hole. Its very tight, in fact sometimes you cant pull it back out and it ends up breaking off inside the part(which is no problem since im just doing testing). Im hoping this isnt the problem. If the parts HAVE to be screwed tot he wire....some of the parts I need to anodize have no way of connecting them.
I'll try it this weekend with agitation and i'll try to watch for PAR. How big of a swing in voltage will there be? Does it matter if you watch the voltage at the supply terminals or at the part(just checking)?
Also, I saw somebody made an agitation thing out of PVC on these forums. Does anybody know if the weight of the PVC itself will hold it down being filled with air?
Thanks guys
