Old 01-16-2004, 04:52 AM
Sid03 Sid03 is offline
Sid03
Fibergeek- Thanks for the reply. To answer your one question, I am using a 40A car battery charger(2/10/40 Amp range plus 200A jump start setting to be more precise), and I made a box that plugs into the wall and contains an outlet on it which is run through a 600W light dimmer switch. Is that what you are looking for? Thanks again.
