for a dye sub printer what you can do is a preimitive form of what can be done with a vinyl cutter.
they sell vinyl sticker paper for certin dye sub printers. what you do is print out on the vinyl paper then cut out what you need to mask. stick it on what your annoing and mask the area and remove the vinyl.
this is a cheaper way if you already have a dye sub printer like an old alps dye sub printer.
also you can find printable sticker paper for ink jet printers. i'll see if i can find the link and post it.
the ones i have found are easy to remove. problem with some sticker papers are there perment once stuck on.
