  #8 (permalink)
Old 01-27-2004, 10:00 PM
NeoMoses NeoMoses is offline
NeoMoses
This is the first I've heard of the 720 rule, so I did a quick google search. Is the following correct?
Originally Posted by finishing.com
You can get a good estimate of the processing time using the '720 Rule' which states that it takes 720 amp minutes per square foot to produce one mil of oxide. The application of this rule is simple. Take 720 and divide it by your current density in amps per square foot. That will be the time required to produce a coating that is one mil thick. It works fairly well for Type II and Type III coatings and for most wrought alloys. Example - how long to produce one mil at 24 amps per square foot? 720 divided by 24 is 30 minutes. So if you want 12 microns it will require 14.2 minutes. Our experience show that this will get you pretty close, say within 10%. You must use current density control, not voltage control, though.
Sjon Westre
METALAST International - Minden, NV, USA
