Old 01-29-2004, 03:58 PM
mansonozz mansonozz is offline
mansonozz
Default Aluminum Engine parts - I'm ok, but I want perfection!
Hello guys, I’m new to the boards hoping to get some help.
I have been polishing engine parts on my car for a while now and am wondering about my process.
I just have been following the way I was told by a friend, which works most the time, but I often run into problems which take forever to fix.
Here’s what I do for aluminum coated in the factory casting junk.
Sand w/40, move to 80, to 120, to 180, 220, 320 to get it as smooth as possible, all chunks out, etc. No dings, dents, bumps, pimples.
Then I move to Tripoli on a spiral sewn wheel.
Lastly I use white rouge. I HAD been using a spiral sewn wheel but moved to a looser flap wheel and haven’t seen much improvement. So I will probably move back to a spiral sewn.
I have been able to produce shiny results but never a perfect mirror-like finish. I’ve gotten to “blurry mirror” status, which still looks amazing from a foot away, but I’m always wanting better. It’s a sickness, as you know!
I’m also using a 1400RPM drill which I’m sure needs to be replaced for something more fit and quick for the job.
Before I move on to the next grit of sanding (which I do on a vibrating sander, then by hand) I always make sure it’s as smooth as I think it can get. I’m thinking I might be missing something here as I do get a few scratches left over. Am I to sand endlessly without seeing or feeling any results? I’m not sure if they are there and I just can’t tell.
Would it be beneficial to use emery before OR in place of tripoli?
Here’s a sunlit picture of my engine for anyone interested. The intake is the part I’m mostly worried about right now, as it’s large and prominent in the engine bay. It’s driving me nuts!
If that doesn’t work, you can click on: http://members.aol.com/mansonozz/engine.jpg
Thanks!
Dave
