Old 02-01-2004, 09:38 AM
dadkar2 dadkar2 is offline
Moderator
Default Gold plating
The Tank plating gold from Caswell is somewhat finnicky. If the temperature is off (either way) more than a few degrees from 140 it will misbehave. I did get good results with it as long as the temperature was carefully maintained. However, it went flat after a few articles for me, too. I was using a gold anode. I don't think it dissolves the gold, but I agree you're better off with a gold anode rather than risking the introduction of even trace amounts of nickel, iron, etc. into the alkaline solution by using a stainless anode.
I have found that the FastGold is fabulous, much easier to use, and longer lasting. Ah, more expensive, too! But--you get what you pay for.
Ken
