a buffing motor with manafactured extended shafts also make it much easier to do the proper cut and color motions as well without fear of bumping into the motor.
another tip is to use pre-split pipe wrap insulation that feels like hard styrofoam insulation and cut it to fit in between the motor housing and the inside of the wheel and incase you do slip inside you want have metal to metal contact and have to possibly sand something again or remove a dent.
bill
