Old 02-02-2004, 06:03 PM
Chevalier Chevalier is offline
Chevalier
Default Power supply control?
I just got a power supply(about 30 min ago!), I am just wondering how you guys set the current on your supply. From what I can tell on mine, I need to turn the voltage limiter off(fully CW - so there is no voltage limit) and have the current limit turned on fully(fully CCW - so there is no current flowing), do I then just adjust the current limit to get the desired current and let the voltage take care of its self?
I am also assuming there is no reason to ramp up the current up slowly as the voltage will be doing this automatically when I set the current?
Thanks.
The supply I bought can be seen here : ( http://www.radionics.ie/cgi-bin/bv/b...oid=-342505991 )
