Thread: oven
Old 02-13-2004, 01:23 PM
geeb57 geeb57 is offline
geeb57
thanks for the info!
The oven will have only the inner steel wall but i plan to enclose it with cinderblock. Insulation between the steel and the block should be sufficient,right? I have two windows from the double oven i'm using so i figured one on each side, so i could get a better view of the "flow out"?
A ceramic "keyless" light fixture should be good for the light i'm guessing just concerned about the heat and wires.
As for "why 10 ga?" the steel supply around here is not into thin material so we have to ..."run what ya brung" lol
One last question: how do you figure material? Is there a rule of thumb as to lb of powder to sq foot of coverage?
Thanks for your help
Pat
