You'll need to grind the ends of the buffer shafts down so the extenders fit on. Than you can modify the hold down screw or tack weld them, in place. Make sure you get the super sisal black, it works much better, and i get better results with the plain old white. Like caswell said, give the free buffing guide a read.
