Old 02-20-2004, 12:18 PM
NautiShine NautiShine is offline
NautiShine
Now that your frame is relatively smooth, you need to make it SMOOTHER! HEY, NO EATING IN CLASS!!! Ok so, now we wet sand the frame. Instead of using just plain ole water, I use a dishwashing detergent with a metal polisher in it, mixed with water.
Then start to wet sand it using 800 grit to 1000 grit
This is a REALLY messy portion of the job. In the end, you'll be left with a stained frame, but will wipe off easily when you're done.
OK CLASS...ITS BREAK TIME!!! DRINK UP!!
