need some some help on an aluminum polishing shopping list.
last summer i removed the anodizing from my 2003 gsxr 600 frame as well as sanded down the rough cast areas on the rear portion. i have everything that i want polished done to the point where i can see myself in them, but they are still a little cloudy. i achived this shine by wet sanding from 400 grit al the way to 2000 grit. now that my arm and shoulder have healed i figured there must be a better way of finalizing th job. so my question is can somebody give me an idea of what i need to finish a 70% done aluminum polish job.
what i need to know:
wheel/compound combination
how to know when to move to the next step
if anyone says sandpaper i just might cry!
also on this style bike it has 2 black plastic ram air tubes that i would like to have chromed. is there another method of doing this without having them dipped? i found a spray type chroming kit on this site a while back that looked exactally like an plating job, but i cannot find it again. any help would be appreciated.
