Old 02-25-2004, 06:27 PM
JHFGSX9D JHFGSX9D is offline
JHFGSX9D
i have had good results with the abrassive wheel system if we are refering to the glue and sand method !! it really dont last any longer then the greasless but it is far more aggressive then greasless it really cuts sanding time down drastically!! i do reccommend this system to anyone !! i use the glue and sand method to cut the casting out then go over it with an 80 grit greasless to get all the scratches out the abbrassive wheel system cuts pretty deep so you need to remove the scratches !! im really bad at explaining stuff like this so if im not very clear ask and i will do my best to explain!!
