Old 02-27-2004, 11:13 AM
bzer1 bzer1 is offline
Perhaps you might want to try sanding off the coathangers. They are coated as well as the buildup you are adding to them when you spray your parts(if you're not changing then between coats) It seems reasonable to me that you're losing your ground. I'd say if your gun is spraying new parts ok then you should clean off your hangers and try it again. Sounds like etyrrany is right on the money.
