Old 02-27-2004, 07:16 PM
red99ls1ta red99ls1ta is offline
red99ls1ta
Originally Posted by bzer1
Perhaps you might want to try sanding off the coathangers. They are coated as well as the buildup you are adding to them when you spray your parts(if you're not changing then between coats) It seems reasonable to me that you're losing your ground. I'd say if your gun is spraying new parts ok then you should clean off your hangers and try it again. Sounds like etyrrany is right on the money.
i think thats what the problem is. i thought about that after i looked at how shiny the hangers were. the ground was on the hanger, i was pushing the button(red light lit up) and everything was as normal... just wasnt taking a charge. im going to try new hangers, then sand off the old ones and try again.
