Old 02-28-2004, 03:22 PM
cdaw cdaw is offline
cdaw
Default Flash copper vs acid copper for PCB Holes
Greetings
My main goal is to plate thru holes on pcb's. And I'm confused on which plating solution I should try. My holes are already conductive using something similar to silvaspray (if it was a Caswell product it'd probably be called silva~goop). I was leaning toward flash copper, but I really don't know what the difference is ~ when it comes to this type of application.
Thanks for your advice.
JT
