Old 02-29-2004, 08:39 AM
jjones9620 jjones9620 is offline
jjones9620
Default new flash&acid copper plating job/burn through
When plating steel with flash copper followed by acid copper, and while sanding this latter plate to fill minor imperfections, if you reach through to the bare steel again is the correct method to remedy this to return part to the flash copper and then once again to the acid copper?
