What kind of machine is it? Most DIY home pc guns are usually 10 to 15psi at the machine. Make sure you pick up a good regulator with a gage on it, and put it at the inlet on the gun side of the airline. Just be aware that you might be turning it up or down depending on the condition of the machine. A good regulator should be less than $15. Don't forget to get a good water seperator to keep the moisture out of your gun and work. Good luck
