WAIT!!!! Before you take that sisal wheel to that frame! You said you sanded up to 2000 grit, and by the way your talking about pain, you may of spent ALOT of time sanding. Hopefully your piece is very smooth with no scratches. I would first try using a spiral with the white, then a cotton loose with the white. If the results are very good, just go over the frame with this combo. If you have cloudiness still, then go back to the SISAL. I just don't want you back tracking and then progressing. I am not knocking Skiddz here, cause he is a pretty smart fella, but I have been where you are and I have done what I just said, with excellent results. If it doesn't work my way, you didn't lose much time and you can then proceed to the sisal and black. Good luck
