Other materials in Anodizing tank?
I was wondering what if any other material could be placed in the tank while anodizing. Specifically, I was wondering if I could use some sort of silicon adhesive to hold the airline in-place, and if the purple compounds used to join PVC piping would be an issue in the tank?
Does anyone know a source for digital thermometers which can be used in the anodize tank as well as the other tanks?
I switched to rectangular poly-propoline tanks (from Lows) and find that the tanks sag somewhat. I have double-tanked to help avoid a spill, but someone suggested that you could easily create a tank using 1/4" PVC-sheet and a plastic welder. Has anyone tried this?
