Originally Posted by Fibergeek
Silicone sealants or PVC adhesive shouldn't bother the chemistry. You need to be concerned with the adhesive tolerating the 5% concentration sulfuric acid electrolyte. Most epoxy/plastic based ones will.
What about a spray-in bedliner product like Rhinoliner? They claim that their product resists acid spills; could I use a metal washtub with a spray-in bedliner sitting on top of a hot plate to use as a heat source, with the plastic agitator tube embedded into the spray liner while wet to provide air bubbles?
