shine after dyeing prob
Just wanted to ask a few questions regarding getting your parts to shine . After coming out of the dye bath the alu parts have a beautiful shine, when the part has been sealed and set the shine seems to dull some what ,the part still has some shine but when it came out of the tank it was just a brillant shine, I know pre polishing will dictate the finish and end result so i did some looking and found caswell clear coat finish that im going to try its a little expensive but i hope it works,if i simply spray the parts with water it makes the part shine so i figure the clear coat should work . Also any suggestions on a good thicking agent for caswell dye? thanks for any suggestions and help!
