Old 03-08-2004, 02:13 AM
skiddz's Avatar
skiddz skiddz is offline
skiddz
That's a good point Fireblade. You can always add some "grit" to step back, but if the white is cutting enough to do the job, stick with it. if it's not, maybe step back to the spiral/tripoli combo and see how that works. Worse comes to worse, step all the way back to sisal/black.
I think if I were to dive in with the white on a spiral wheel, I'd try to buff perpendicular to the sanding direction for starters and see how that goes...
Good luck!
