Old 03-08-2004, 10:28 PM
BikerBill BikerBill is offline
BikerBill
Default More gas oven questions and a few good links
Hello again,
I am near completion of my large oven. I am stuck on using a gas fired heater. I know eveyone says do not do it, but I really haven't found out why.
I understand the explosive factor while spraying.
There is a "SLIGHT" risk of a circulating fan moving some stray powder to the source of an ignition. That could easily be eliminated with proper filtering.
I did some searching and found that the powder itself will become flammable around 900 degrees.. far above the curing point.
The fumes given of during curing are definitely not flammable.
So what is the real problem with gas fired ovens ? Is it just a liability issue the suppliers are using to cover them selfs from some idiot who tries to spray inside a lit gas oven
Look at the following links I have found for information on ovens and tell me what I am missing ?
http://www.coatings.de/manual/kap5-5.pdf
look at the image on the bottom of the page of a gas fired burner with a built in filter.
Also look at http://www.coatings.de/manual/kap5-2.pdf
this burner box looks as though small amounts of dust could come into contact with an open flame.
Any reason why I could not incorporate these ideas into my oven. I have the parts and knowledge to assemble a safe burner and controls. My only concern is all the talk about not using gas fired ovens for PC.
Aside from that here is a good link for a lot PC info
http://www.coatings.de/pcmanual.cfm
Bill
