Old 03-13-2004, 11:49 AM
bhhodges bhhodges is offline
Moderator
bhhodges is on a distinguished road
if your going to be plating thousands of rings you would be better off buying some gold anodes to replenish the gold in the plating tank. yes you need two connections from the rectifier one positive connected to the anode/anodes and one negative to the buss bar the part/parts hang from. any hardware store would have the copper pipe to use for this. . im not sure what you mean buy ---is this dangerous with 3 amps---?? if you are only gonna plate a few rings at a time i doubt you will ever have to use 3 amps . im also a firm believer in electrocleaning parts prior to plating which is hooking up the part positive and the anode negative in an electrocleaner bath and its ---to keep it simple--"reverse" plates sorta similar to placing an alkaseltser in water. the electrocleaner removes all junk that shouldnt be on a item before plating. when i first started plating a year ago i thought i could clean with soap and water and then plate but it didnt work to well,i only thought i was getting a water break test. also what is the base metal of the rings your gold plating?
bill
