Old 03-14-2004, 10:00 PM
cgworth cgworth is offline
cgworth
Default Copy Chrome on engine parts and plastic, alot of can I's
i just bought a copy chrome kit and have a few questions. I will be abreviatting copychrome with cc
1. Can I cc parts that have bolts or screws in them? i know this sounds lazy but a few parts i want to do are made of aluminum and were put together at the factory with some sort of epoxy and then screwed together. i will end up damageing the part by taking it apart.
2. can i cc parts that have to differant metals on them , Like above these parts were done at the factory and it is aluminum and had what looks like a brass fitting.
3. can i cc a part with out it getting inside the part. Do i just tape off the part i dont want chrome. an example is a set of valve covers they are flat unlike the olderones that were 2 inchs or so tall, and the bottom of the valve cover has a recessed grove that is just big enough for the gasket and im afraid that if i crome it the gasket will no longer fit. also this part is never going to be seen and will be covered with hot oil in the first 5 minutes. how do i plug the holes, cracks etc while im am cc'ing? will tape etc come off in the process?
4. Like above i have a plastic intake manifold that i want to cc but i dont want it to get to the intake runners or ressed gasket grooves. I bought silva spray to do the plastic by the way. <--- any advice on cc plastic would be helpful here
5. can i do nuts and bolts or should i just do the heads? will this change the thread size? and can i just throw them all in a basket and and dip them in?
6. Can i cc moving parts. I have a few parts they move like belt tensioners that are spring loaded and cannot be takin apart can i cc them and then exercise the part and break the cc where it covered the moving section or will this look like ****?
7. can i cc one side of an object and the flip it around and do the other side without leaving a seam?
8. does it matter what container i use to copy chrome i was thinking of useing like a square rubbermaid container so i can get some awkward parts in
Please do not flame me i am new and have yet to do any of this. I really need these questions answered before i proceed so i do not mess up some expensive parts. any advise would be helpful
