Dye problems with bead blasted finishes
I've been doing polished finishes with great success and virtually no problems that were not of the operator related variety. I was doing some step-wedge calibrations and color blends for color densities tonight when I noticed problems with the back side of my tests. The front side was roughly polished while the back was bead blasted. The back side (bead blasted side) of each of the pieces did not take color at the same rate as the polished side of the test piece. The bead blasted side was very flat and uncolored looking, where as the oposite (polished) side which recieved the same dye duration in the same step area showed an time appropriate color density. How can I get good color on a bead blasted finish? I'm not having much luck.......... Thanks,
EasTTex
