Old 03-15-2004, 10:24 AM
Stryder Stryder is offline
Stryder
I found two types of references. One dealing with mechanical removal (blasting) and others with the electro-chemical. Basically it seems you don't want to do the electro-chemical yourself unless you are set up to do chrome already. It's the same process in reverse.
I think electro-chemical will yield better results but then again for a small set of parts it may not matter.
Blasting:
http://www.caswellplating.com/bbs/viewtopic.php?t=1453
Info on electro-chemical:
http://www.nmfrc.org/crarchive/jun02b.cfm
http://www.finishing.com/1400-1599/1476.html
Caswell sells chroming setups... the instruction manual they have would be a good start towards understanding the process. See:
http://www.caswellplating.com/kits/index.html
