Old 03-30-2004, 12:52 PM
Cyberave68 Cyberave68 is offline
Cyberave68
Default Anodizing Problem????
Hello to all who see,
I am experiencing a weird problem. I folow all the steps to get to the anodizing tank properly. The anodinzing tank is where my problem starts. I have 1 gal battery acid to 3 gals of distilled water mix. The 600w dimmer swtich setup from the manual. A alum tank bar drilled and taped for the wires. When i get to this tank I have a small peice of alum. about 8" sq face value. My amps are at .5-.75 for such a small part. I set my timer for 1 1/2 hours and check up on it every half hour. After about an hour to an hour an 15 mins my titanium wire disolves at the water level.... I dont think i have anything wired wrong but can draw up a diagram for anyone who wants to see. pics i can take too. The first time this happened i did continue to the dyeing process and did sucsessfully dye the part.( a very thin layer i might add but it did dye)Any and all comments welcome. i will be trying alum wire tonite and will post any results in here.
Thanks for your time,
Cyber(Erik)
