Not for sure why you can't see them
I wish it came out that way. It comes out of the oven all chalky and you have to either bead blast it off or use 0000 steel wool to remove it. If you can afford a large enough tumbler, than it will cut the work in half. Once the chalky residue is removed, you treat it like a bare piece of aluminum that you are going to polish.
