Brown & White don't work
OK, I've been gaining experience for about 2 months now and really nothing to show for it because I can't get the brown and white to polish like they are suppose to.
I have gotten good at the black. I am polishing 1.5 inch square tubing. By switching off different wheels I can get the finish just like glass. The only thing left is a lack of color and surface scratches from the black.
When I go to brown or if I skip the brown and go to the white. I immediately get a haze on the metal. There is polishing going on but it is a dull shine. I can touch it up with the black and it will polish right back up and will have a little better color but still have the surface scratches from the black. If I heat the metal with the wheel like I do using the black, the haze goes away, the color gets better but the metal finish distorts. I get a slight waviness to the finish, at times I have even gotten an orange peel effect. When compared to the black results you can definitely see a difference in the smoothness. The black has a consistent reflection where as the brown or white results has a slight distorted reflection.
I am using a 3/4" buffer and 6" wheels, I have tried 8" and I have tried a hand polisher that can generate more heat. I have literally tried every combination but I just can't seem to get the results I expect. I would think that if I can get a glass like finish with black that following up with the brown or white should produce outstanding results because all the work is done with the black. It should be just a matter of polishing out the surface scratches and adding a little color.
