Old 07-25-2002, 12:45 PM
Shevalik Shevalik is offline
Shevalik
Default Re: plating equipment
I have the same idea. I have a two gallon kit, so I am one step ahead. I believe the best way, is to get started small and master the process before investing the money on a larger line. I have found that the main factor to consider in getting started is the actual power supply you will be using to plate with. A 25 amp power supply will allow you to do the copper and nickel plate on just about any thing on a bike, the chrome process requires significantly more power. With a 25 amp power supply, your biggest piece that you will be able to chrome would probably be a master cylinder or handle bar controls, bolts, maybe headlight bezels, etc.
