Old 04-09-2004, 02:58 PM
customandsound
Guest
Posts: n/a
this was done with a little craftsman grinder it is ok looking .... and the list you got is good for starters .... after you get good you will want to try other things .... i don't use sisal anymore...... it is sprial for most of the work....... if you sand the part good and smooth a sprial with black will bring you a nice shine and then to white on a sprial .... skipping out the brown.... you will learn alot of tricks
