Originally Posted by JohnG
hi!
I am polishing the cast aluminum valve cover from an old SOHC Honda 750. The polishing is coming along ok...learning as I go.
Eventually I will get it to where I'm happy with it. The question then comes up: what to put on it to protect it?? While I can find a number of sealers around, my concern is with the temperature that the piece may be subjected to. I really don't know how hot the valve cover gets so I want to be on the conservative side. Put differently, I don't want to be sitting in traffic in July, look down and see the sealant flaking off!!!
Any advice appreciated.
John - MA
don't worry about the temp of the part ... that is friction that comes with polishing ... i never warped a part by polishing it .... you can either zoop the part when done ... or give it a good coat of high grade carnuba wax ..
