Old 04-13-2004, 10:25 PM
jtagger19 jtagger19 is offline
Are you going with gas or electric? I built a oven the same size and I run 15K watts to heat it. Four 3000 watt elements. If you go with gas a think 11,000 btu's should work , but not sure.
I'm new at this I'm in the process of acuaring a bigger electric oven
can you use a GAS ovens I was told that gas ovens didn't work cause they have emitions and powder is flamable . if thi is the case
I have 2 big gas ovens that I might use then.
