Old 04-14-2004, 10:13 AM
ecollins ecollins is offline
ecollins
Default Trying to buff primary cover- not coming out to good
Small parts come out good, larger parts do not. I am trying to buff my aluminum primary cover that is from my triumph motorcycle. Here's my setup and technique.
1) 6" buffing wheel set from caswell (sisal, spiral, cotton, canton flannel).
2) compound set bought from sears (black, brown, white, red).
3) no-name 3/4 hp bench grinder bought from joblot for $30.
I wet sand up to 600 grit. Take the piece to the sisal wheel w/black compund. I use a left to right motion. It looks a little shiny after this.
I then move to spiral wheel with brown compound. Again using a left to right motion. I expect piece to look much nicer but it looks duller with more noticeable scratch lines.
I wonder if my cheap bench grinder is too weak to properly cut or if the compound that comes from sears sucks or if it is my technique. It is pretty easy to bog down the grinder (I can almost stop it with my hands!) Before I lay down money for a new buffer, I was hoping someone could tell me my cheapo bench grinder is fine and my technique needs to be changed. Thanks!
-ethan
