First I think you need to spend more time on the black/sisal combo, that will be the majority of the buffing. Buff until it looks close to the finish that you want. Second make sure you a cleaning all the compound off the part before switching to brown. Use brake parts cleaner, then Dawn and HOT water, and make sure it is completely dried. Third, rake the spiral wheel before you put on the brown to make sure the black dust hasn't gotten all over the spiral wheel and will make scratches. And remember use a little compound and use it often. Keep practicing, it will get better.
