Contamination w/rinse?
Neophyte to plating so easy on the answers to my questions. Read manual several times before setting up tanks but may have missed the most important issue about rinsing with fresh water. Note: most forum replies indicate to use distilled water for all rinsing which will prevent cross contamination of plating tank solution. Question is (flash copper/bright copper) tanks affected by using fresh water & if so can these solutions be purged of contaminates or will solution need to be dumped?
