Thread: hi-temp silicon
Old 05-03-2004, 11:07 PM
Blademan's Avatar
Blademan Blademan is offline
Blademan is on a distinguished road
Default hi-temp silicon
While back I asked if you could use Hi- temp silicon in the squezzzzze tube for masking...this is the responce I recieved back from Loc-tite...
Wayne,
Thank you for your inquiry. While the high-temperature silicone will
withstand the temperature, the adhesion may be more than you want. You can
try it, but often baking a silicone can make it tougher to remove later.
Mineral spirits can be used to swell up a cured silicone to remove it.
Regards,
Cathy
so now ..I gotta play.....
