Old 05-03-2004, 10:57 PM
WAORacing WAORacing is offline
WAORacing
If the powder is recomended to cure at 400 then that is what you should do. the powder will flow out when the part temp starts getting around 250 or so. once the part has reach 400 thats when your cure time starts. If you do want to clear a base color you do cure the base color and then clear and cure that.
