I'm going to say this one more time:
If you don't yet have the necessary experience with the anodizing process (LCD or otherwise) so that you can tell when you have a bad connection and not some other problem, stick to tightly bolting or threading the work with soft aluminum wire. We have been through months of problems caused by beginners with lousy electrical connections, let's not go through that again.
NeoMoses as moderator, and M_D as an accomplished anodizer, it would be appropriate you to help me amplify this.
