Fibergeek is 100% correct. To drive home exactly how tight the connections are between my workpiece and the wire, realize that I need pliers to squeeze the wire together. Depending on the part and the geometry, I'm getting 20-30 pounds of clamping force. There is absolutely no 'wiggle' or 'play' in the connection. Don't just think that you can loop a wire and let a part hang from it in the electrolyte bath, it's much more detailed than that.
