great!
What a great, informative reply.
I was going to purchase a cutter/grinder that spins 11K rpms also. Is this excessive?? The problem with doing a wheel with a bench grinder is the size of the wheel makes it unruley and difficult to handle for any extended period of time. I need some way of working with it while it's lying down. I guess your idea of a flex-shaft would be best if you don't recommend the grinder/buffer.
How much of the Brown and White triploi should I order? Approximatly how long does a bar last?
Thanks again for such prompt and helpful replies.
