  #21 (permalink)
Old 05-23-2004, 09:27 PM
Sid03 Sid03 is offline
Sid03
So, how do you detect PAR with 2000series? Will the voltage stop dropping? As for temp. control......I got a larger container to sit the ano tank in. Going to add water and some ice.....just have to play around and get a feel for how much ice to add right before starting to anodize I guess.
As for ventilation.....any tricks of the trade for that? I do have a wall mounted ventilation fan but it isnt keeping up. I was thinking of having a fan near the ano tank to suck fumes into a dryer hose and run that hose up to the wall vent. Think that would be enough? How lethal are sulfuric acid fumes?
Also, I do alot of 2 color parts. While doing the second color on a part I can see the already colored side starting to dry. Is it bad to let it dry? I try to keep it wet by spray with water every once in awhile......does it matter?
Thanks
