  #29 (permalink)
Old 05-24-2004, 06:55 PM
M_D,
Even with cathode area that much larger than the work you should still see a change in voltage when you disconnect 1 plate, probably not as much as Sid. Ideally the voltage should go up, and the indicated current should remain the same. Kindly post your results also.
Your 5 minute staggered testing would be cheating in true Kentucky Windage anodizing, good idea.
