You shouldn't have any problem. The key thing is in the prep work. Make sure you have CLEAN parts. Between prep and transferring into the oven after you have coated the part, spraying the powder is most definitely the easiest. You'll enjoy it, i have no doubt about that. The most amazing thing about the whole powder coat thing is watching it flow out. Good Luck!!!
Mike
