Re: Remove chrome plating from plastic
You can very carefully reverse plate the chrome off, using an acid pickle. You should be able to remove the chrome layer down to the nickel underneath without harming the plastic.
It\'s unlikely that a bit of acid on the plastic will harm it anyway....after all the acid probably came in a plastic container, right?
You can also buff it off.
